Salta al contenuto principale
Asus X540S notebook PC Hard drive Replacement
Cosa ti serve
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S notebook PC Hard drive  Replacement: passo 2, immagine 1 di 1
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S notebook PC Hard drive  Replacement: passo 3, immagine 1 di 3 Asus X540S notebook PC Hard drive  Replacement: passo 3, immagine 2 di 3 Asus X540S notebook PC Hard drive  Replacement: passo 3, immagine 3 di 3
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
  3. Asus X540S notebook PC Hard drive  Replacement, Hard drive: passo 4, immagine 1 di 2 Asus X540S notebook PC Hard drive  Replacement, Hard drive: passo 4, immagine 2 di 2
    • Remove the one Philips #1 screw.
    • Slide the hard drive out.
  4. Asus X540S notebook PC Hard drive  Replacement: passo 5, immagine 1 di 2 Asus X540S notebook PC Hard drive  Replacement: passo 5, immagine 2 di 2
    • Remove the four Philips #1 screws.
Conclusione
Altre 18 persone hanno completato questa guida.
Padraic Hoselton
Membro da: 08/22/17
4.180 Reputazione
12 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
7 Commenti
Looks simple enough Padraic. Thanks. Does a new install of win10 come already copied in a new HDD? Would this replacement be and different if I used a digital drive? (My old hd failed and I have no system).
sludge - Replica
After installing an OEM replacement HDD in my x540, I bought a flash drive on Amazon for$10 that rebooted my Windows 10 and it's working like a brand new machine.
I believe the product key for windows 10 is embedded in motherboard.
F S -
F S - Replica
Hi … How can a flashdrive reboot a Win10 on a new SDD /HDD ? A Windows flash drive contains a Win10 bootable ISO ?
On Amazon, I found flash drives with a product key but I don’t know where the new installation can be done from if there is no ISO on it …
(I have a x540 with a dead HDD …)
gnogno35 -
And thank you Padraic
F S - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 61
Tutti i Tempi: 13,862
