Salta al contenuto principale
Asus X502C-RB01 Fan Replacement
Cosa ti serve
  1. Asus X502C-RB01 Fan Replacement, Keyboard Panel: passo 1, immagine 1 di 1
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 Fan Replacement: passo 2, immagine 1 di 1
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 Fan Replacement: passo 3, immagine 1 di 2 Asus X502C-RB01 Fan Replacement: passo 3, immagine 2 di 2
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 Fan Replacement: passo 4, immagine 1 di 2 Asus X502C-RB01 Fan Replacement: passo 4, immagine 2 di 2
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 Fan Replacement: passo 5, immagine 1 di 1
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
  6. Asus X502C-RB01 Fan Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
  7. Asus X502C-RB01 Fan Replacement: passo 7, immagine 1 di 1
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
  8. Asus X502C-RB01 Fan Replacement: passo 8, immagine 1 di 1
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
  9. Asus X502C-RB01 Fan Replacement, Motherboard: passo 9, immagine 1 di 1
    • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
    • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
  10. Asus X502C-RB01 Fan Replacement: passo 10, immagine 1 di 1
    • Unplug the bundled cable by pulling it away from the connector with a bit of force.
    • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
    • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
  11. Asus X502C-RB01 Fan Replacement: passo 11, immagine 1 di 2 Asus X502C-RB01 Fan Replacement: passo 11, immagine 2 di 2
    • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
  12. Asus X502C-RB01 Fan Replacement: passo 12, immagine 1 di 1
    • Gently lift the motherboard out of the casing.
  13. Asus X502C-RB01 Fan Replacement, Fan: passo 13, immagine 1 di 1
    • Flip the motherboard over so the fan is right side up.
  14. Asus X502C-RB01 Fan Replacement: passo 14, immagine 1 di 1
    • Disconnect the fan from the motherboard by pulling the power cable connector.
  15. Asus X502C-RB01 Fan Replacement: passo 15, immagine 1 di 1
    • Remove the two 5.5mm screws using a Phillips #0 head screwdriver.
  16. Asus X502C-RB01 Fan Replacement: passo 16, immagine 1 di 1
    • Detach the tape that connects the fan to the heatsink.
  17. Asus X502C-RB01 Fan Replacement: passo 17, immagine 1 di 1
    • Lift the fan off to remove it from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Frances Tan
Membro da: 01/19/17
143 Reputazione
1 Guida realizzata
UC Davis, Team 1-5, Rodger Winter 2017 Membro di UC Davis, Team 1-5, Rodger Winter 2017
UCD-RODGER-W17S1G5
4 Membri
6 Guide realizzate
Un commento
Great guide. Re: STEP 11 - my Asus notebook had 5 screws securing the mb.
u1oo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 826
