Salta al contenuto principale
Asus X501A-RH31 Keyboard Replacement
Cosa ti serve
  1. Asus X501A-RH31 Keyboard  Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Keyboard  Replacement: passo 2, immagine 1 di 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Keyboard  Replacement: passo 3, immagine 1 di 2 Asus X501A-RH31 Keyboard  Replacement: passo 3, immagine 2 di 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Keyboard  Replacement, Keyboard: passo 4, immagine 1 di 2 Asus X501A-RH31 Keyboard  Replacement, Keyboard: passo 4, immagine 2 di 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Keyboard  Replacement: passo 5, immagine 1 di 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Keyboard  Replacement: passo 6, immagine 1 di 2 Asus X501A-RH31 Keyboard  Replacement: passo 6, immagine 2 di 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Keyboard  Replacement: passo 7, immagine 1 di 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Keyboard  Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
Conclusione
Romana Hruby
Membro da: 10/20/17
596 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,210
