Salta al contenuto principale
Asus X401A Processor Replacement
Cosa ti serve
  1. Asus X401A Processor Replacement, Processor: passo 1, immagine 1 di 2 Asus X401A Processor Replacement, Processor: passo 1, immagine 2 di 2
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: passo 2, immagine 1 di 3 Asus X401A Processor Replacement: passo 2, immagine 2 di 3 Asus X401A Processor Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: passo 3, immagine 1 di 3 Asus X401A Processor Replacement: passo 3, immagine 2 di 3 Asus X401A Processor Replacement: passo 3, immagine 3 di 3
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: passo 4, immagine 1 di 3 Asus X401A Processor Replacement: passo 4, immagine 2 di 3 Asus X401A Processor Replacement: passo 4, immagine 3 di 3
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: passo 5, immagine 1 di 1
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: passo 6, immagine 1 di 1
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: passo 7, immagine 1 di 2 Asus X401A Processor Replacement: passo 7, immagine 2 di 2
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: passo 8, immagine 1 di 1
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: passo 9, immagine 1 di 3 Asus X401A Processor Replacement: passo 9, immagine 2 di 3 Asus X401A Processor Replacement: passo 9, immagine 3 di 3
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: passo 10, immagine 1 di 2 Asus X401A Processor Replacement: passo 10, immagine 2 di 2
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: passo 11, immagine 1 di 2 Asus X401A Processor Replacement: passo 11, immagine 2 di 2
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: passo 12, immagine 1 di 3 Asus X401A Processor Replacement: passo 12, immagine 2 di 3 Asus X401A Processor Replacement: passo 12, immagine 3 di 3
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
Conclusione
Altre 2 persone hanno completato questa guida.
Tyler Stiles
Membro da: 02/07/17
152 Reputazione
1 Guida realizzata
Ohio State, Team 1-4, Wilder Spring 2017 Membro di Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 Membri
5 Guide realizzate
Un commento
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,830
