Salta al contenuto principale
Asus X200MA Wireless Card Replacement
Cosa ti serve
  1. Asus X200MA Wireless Card Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Wireless Card Replacement: passo 2, immagine 1 di 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Wireless Card Replacement: passo 3, immagine 1 di 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • Take gold cap that connects to a black wire off using the metal spudger.
  5. Asus X200MA Wireless Card Replacement: passo 5, immagine 1 di 1
    • Remove the following two screws:
    • Two 4 mm screws using Phillips #0 screwdriver.
  6. Asus X200MA Wireless Card Replacement: passo 6, immagine 1 di 1
    • Slide the component up and out.
Conclusione
Altre 2 persone hanno completato questa guida.
Vanessa Garcia
Membro da: 01/22/15
1.763 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
8 Guide realizzate
Un commento
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,052
