Salta al contenuto principale
Asus X200MA Trackpad Replacement
Cosa ti serve
  1. Asus X200MA Trackpad Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Trackpad Replacement: passo 2, immagine 1 di 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Trackpad Replacement, Trackpad: passo 3, immagine 1 di 2 Asus X200MA Trackpad Replacement, Trackpad: passo 3, immagine 2 di 2
    • Use the spudger to lift up and remove the black plastic covering.
  4. Asus X200MA Trackpad Replacement: passo 4, immagine 1 di 1
    • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  5. Asus X200MA Trackpad Replacement, Mouse: passo 5, immagine 1 di 1
    • Remove wider blue strip with tweezers.
  6. Asus X200MA Trackpad Replacement: passo 6, immagine 1 di 1
    • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
  7. Asus X200MA Trackpad Replacement: passo 7, immagine 1 di 1
    • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
  8. Asus X200MA Trackpad Replacement: passo 8, immagine 1 di 2 Asus X200MA Trackpad Replacement: passo 8, immagine 2 di 2
    • Use metal spudger to get in between mouse pad and keyboard and lift off.
Conclusione
Vanessa Garcia
Membro da: 01/22/15
1.763 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,094
