Salta al contenuto principale
Asus X200MA Screen Replacement
Cosa ti serve
  1. Asus X200MA Screen Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Screen Replacement: passo 2, immagine 1 di 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Screen Replacement: passo 3, immagine 1 di 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Screen Replacement, Battery: passo 4, immagine 1 di 1
  5. Asus X200MA Screen Replacement: passo 5, immagine 1 di 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Screen Replacement: passo 6, immagine 1 di 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Screen Replacement: passo 7, immagine 1 di 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Screen Replacement: passo 8, immagine 1 di 1
    • Slide the battery up and out.
  9. Asus X200MA Screen Replacement, Screen: passo 9, immagine 1 di 1
    • Remove the following four 3 mm screws using the Phillips #0 screwdriver.
  10. Asus X200MA Screen Replacement: passo 10, immagine 1 di 2 Asus X200MA Screen Replacement: passo 10, immagine 2 di 2
    • Lift and separate the screen from the base plate.
  11. Asus X200MA Screen Replacement: passo 11, immagine 1 di 2 Asus X200MA Screen Replacement: passo 11, immagine 2 di 2
    • Insert the metal spudger into the side of the screen casing. Work the spudger around the perimeter of the casing in a rowing motion in order to release the plastic clips holding the casing together.
    • Place a finger in the space between the casing while undoing the clips to keep the casing from re-closing.
  12. Asus X200MA Screen Replacement: passo 12, immagine 1 di 1
    • Lift the half of the casing with the screen away from the other half of the casing and place the screen half on a work space by itself.
  13. Asus X200MA Screen Replacement: passo 13, immagine 1 di 1
    • Remove the following six 3 mm screws using the Phillips #0 screwdriver.
  14. Asus X200MA Screen Replacement: passo 14, immagine 1 di 3 Asus X200MA Screen Replacement: passo 14, immagine 2 di 3 Asus X200MA Screen Replacement: passo 14, immagine 3 di 3
    • Use the jimmy tool to peel the following stickers from the screen:
    • The silver sticker near the bottom.
    • The information sticker near the top.
  15. Asus X200MA Screen Replacement: passo 15, immagine 1 di 3 Asus X200MA Screen Replacement: passo 15, immagine 2 di 3 Asus X200MA Screen Replacement: passo 15, immagine 3 di 3
    • Lift the latch holding the component in place.
    • Remove the component by pulling in the direction of the arrows.
  16. Asus X200MA Screen Replacement: passo 16, immagine 1 di 2 Asus X200MA Screen Replacement: passo 16, immagine 2 di 2
    • Lift the screen from the casing and place the two next to one another.
Conclusione
IUPUI, Team S2-G4, Stella Fall 2019 Membro di IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 782
