Salta al contenuto principale
Asus X200MA Fan Replacement
Cosa ti serve
  1. Asus X200MA Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Fan Replacement: passo 2, immagine 1 di 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Fan Replacement, Battery: passo 3, immagine 1 di 1
    • Take two rubber caps off the back side of the laptop.
  4. Asus X200MA Fan Replacement: passo 4, immagine 1 di 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  5. Asus X200MA Fan Replacement: passo 5, immagine 1 di 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  6. Asus X200MA Fan Replacement: passo 6, immagine 1 di 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  7. Asus X200MA Fan Replacement: passo 7, immagine 1 di 1
    • Slide the battery up and out.
  8. Asus X200MA Fan Replacement, Fan: passo 8, immagine 1 di 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  9. Asus X200MA Fan Replacement: passo 9, immagine 1 di 2 Asus X200MA Fan Replacement: passo 9, immagine 2 di 2
    • Unplug the set of wires located at bottom corner on fan.
  10. Asus X200MA Fan Replacement: passo 10, immagine 1 di 2 Asus X200MA Fan Replacement: passo 10, immagine 2 di 2
    • Lift up and out to completely the remove fan component.
Conclusione
Altre 3 persone hanno completato questa guida.
Vanessa Garcia
Membro da: 01/22/15
1.763 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,366
