Introduzione
If your battery is giving you a hard time on your laptop, follow this guide.
Cosa ti serve
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Look at comments in the previous step. There are 2 more screws.
Altre 30 persone hanno completato questa guida.
8Commenti sulla guida
Merci super!
Thanks for the write up! Easy to follow, Great photos, and worked great!
thanks it worked
Your step by step instructions were so easy to follow. Great job. Thanks! :)
I would like to buy a battery to it, Please suggest me the best portal site
Worked like a charm — Thank you!!!!
My 8-year-old and I completed this together in about 20 minutes. Very straightforward.
There are also two other screws under the rubber feet above the battery.
digg1024 - Replica
I agree. Two another 14 mm screws under the rubber feet.
shao.onii - Replica
