Salta al contenuto principale
Asus X200MA Battery Replacement
Cosa ti serve
  1. Asus X200MA Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: passo 2, immagine 1 di 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: passo 3, immagine 1 di 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: passo 4, immagine 1 di 1
  5. Asus X200MA Battery Replacement: passo 5, immagine 1 di 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: passo 6, immagine 1 di 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: passo 7, immagine 1 di 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: passo 8, immagine 1 di 1
    • Slide the battery up and out.
Conclusione
Altre 29 persone hanno completato questa guida.
Vanessa Garcia
Membro da: 01/22/15
1.763 Reputazione
6 Guide realizzate
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
8 Guide realizzate
8 Commenti
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - Replica
thanks it worked
iqbal nasution - Replica
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - Replica
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 70
Tutti i Tempi: 35,371
