Salta al contenuto principale
Asus X200CA-HCL 1104G Motherboard Replacement
Cosa ti serve
  1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Motherboard Replacement: passo 2, immagine 1 di 1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
    • Slide out the hard drive
  4. Asus X200CA-HCL 1104G Motherboard Replacement: passo 5, immagine 1 di 1
    • Detach speaker
  5. Asus X200CA-HCL 1104G Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove motherboard screws
    • These would be located on the green panel which is the motherboard
    • Carefully remove motherboard
Conclusione
Svetlana Pimentel
Membro da: 10/17/17
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 379
