Salta al contenuto principale
Asus X200CA-HCL 1104G Headphone Jack Replacement
Cosa ti serve
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: passo 1, immagine 1 di 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 3, immagine 1 di 1
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 4, immagine 1 di 2 Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 4, immagine 2 di 2
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
Conclusione
Samantha Wahl
Membro da: 10/17/17
301 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 136
