Salta al contenuto principale
Asus X200CA Motherboard and RAM Replacement
Cosa ti serve
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: passo 1, immagine 1 di 2 Asus X200CA Motherboard and RAM Replacement, Keyboard: passo 1, immagine 2 di 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: passo 2, immagine 1 di 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: passo 3, immagine 1 di 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: passo 4, immagine 1 di 1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: passo 5, immagine 1 di 2 Asus X200CA Motherboard and RAM Replacement: passo 5, immagine 2 di 2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: passo 6, immagine 1 di 2 Asus X200CA Motherboard and RAM Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: passo 7, immagine 1 di 2 Asus X200CA Motherboard and RAM Replacement: passo 7, immagine 2 di 2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: passo 8, immagine 1 di 1
    • Lift the motherboard/RAM out from the frame.
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team S1-G2, Leahy Fall 2017 Membro di USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 100
Tutti i Tempi: 8,852
