Salta al contenuto principale
Asus X200CA Keyboard Replacement
Cosa ti serve
  1. Asus X200CA Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Asus X200CA Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Keyboard Replacement: passo 2, immagine 1 di 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Keyboard Replacement: passo 3, immagine 1 di 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team S1-G2, Leahy Fall 2017 Membro di USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,072
