Salta al contenuto principale
Asus W2W-A1 Keyboard Replacement
Cosa ti serve
  1. Asus W2W-A1 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Asus W2W-A1 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Asus W2W-A1 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Keyboard Replacement: passo 3, immagine 1 di 1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Keyboard Replacement: passo 4, immagine 1 di 2 Asus W2W-A1 Keyboard Replacement: passo 4, immagine 2 di 2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
Conclusione
Joe Redfearn
Membro da: 04/14/14
97 Reputazione
1 Guida realizzata
Cal Poly, Team 13-29, Maness Spring 2014 Membro di Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 233
