Salta al contenuto principale
Asus W2W-A1 Hard Drive Replacement
Cosa ti serve
  1. Asus W2W-A1 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Before disassembly, make sure the laptop is powered off and the battery is disconnected.
    • Remove the two screws (size?) on the lower panel at the bottom of the laptop (identify tool to use).
  2. Asus W2W-A1 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Grab the panel and lift upwards while pulling towards yourself.
  3. Asus W2W-A1 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the 3 4 mm Phillips upper screws holding the hard drive down.
  4. Asus W2W-A1 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Pull the hard drive towards yourself to disconnect it from the laptop.
  5. Asus W2W-A1 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Lift the hard drive upwards to remove it from the laptop.
Conclusione
Nolan Schock
Membro da: 04/14/14
501 Reputazione
5 Guide realizzate
Cal Poly, Team 13-29, Maness Spring 2014 Membro di Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 275
