Introduzione
Remove the disc drive on your Asus W2W-A1 so that you may replace it with a new disc drive or a stick a hard drive in its place.
Parti
Nessuna parte richiesta.
Use a Phillips head screwdriver to remove the one 3mm screw labeled D on the back of the laptop.
  • Use a Phillips head screwdriver to remove the one 3mm screw labeled D on the back of the laptop.
Aggiungi Commento
With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
  • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
Aggiungi Commento
Conclusione
Emily Mullins
Membro da: 14/04/2014
201 Reputazione
2 Guide realizzate
Cal Poly, Team 13-29, Maness Spring 2014 Membro di Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 184
