Salta al contenuto principale
Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement
Cosa ti serve
  1. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: passo 2, immagine 1 di 2 Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: passo 2, immagine 2 di 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: passo 3, immagine 1 di 3 Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: passo 3, immagine 2 di 3 Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: passo 3, immagine 3 di 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: passo 4, immagine 1 di 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement, CMOS Battery: passo 5, immagine 1 di 1
    • Disconnect the CMOS battery and its wire from the connector. The CMOS battery is now disconnected from your device.
Conclusione
Kevin Kochanek
Membro da: 11/06/18
181 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,623
