Salta al contenuto principale
Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement
Cosa ti serve
  1. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 2, immagine 1 di 2 Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 2, immagine 2 di 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 3, immagine 1 di 3 Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 3, immagine 2 di 3 Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 3, immagine 3 di 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 4, immagine 1 di 1
    • Lift off the cover and remove the back cover from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S10-G3, Thompson Fall 2017 Membro di USF Tampa, Team S10-G3, Thompson Fall 2017
USFT-THOMPSON-F17S10G3
4 Membri
6 Guide realizzate
Un commento
thank you. this guide was a hugh help to me.
Stephanie Square - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 53
Tutti i Tempi: 21,312
