Salta al contenuto principale
Asus Vivobook Flip 14 TP410U LCD Assembly Replacement
Cosa ti serve
  1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement, LCD Assembly: passo 1, immagine 1 di 1
    • Turn off the power and disconnected the AC cable from the laptop.
  2. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: passo 2, immagine 1 di 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: passo 2, immagine 2 di 2
    • Remove the rubber covers for the two screws located at the bottom of the screen.
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws outlined in the image.
  3. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: passo 3, immagine 1 di 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: passo 3, immagine 2 di 2
    • Excessive force may cause damage to connections.
    • Rotate the screen 360 degrees for ease of access.
    • Place the opening tool at the corner of where the screen meets the base of the laptop.
    • Pry open the screen along the edge until it is completely off the front cover.
    • Disconnect each appropriate connector while opening up the laptop.
  4. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: passo 4, immagine 1 di 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: passo 4, immagine 2 di 2
    • Excessive force should avoided since damage may accrue.
    • Remove the cable that connects to the touch display, front camera, and motherboard.
    • Remove each piece of tape that holds down each cable.
  5. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: passo 5, immagine 1 di 1
    • Have the new LCD display fully unboxed and ready to be used.
    • Remove the old LCD display.
    • The touch screen sensor is extremely fragile, make sure to not put excessive force on the cable while assembling.
Conclusione
Altre 2 persone hanno completato questa guida.
Dominic Bento
Membro da: 03/22/22
334 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,110
