Salta al contenuto principale
Asus VivoTab RT TF600T Webcam Replacement
Cosa ti serve
  1. Asus VivoTab RT TF600T Webcam Replacement, Webcam: passo 1, immagine 1 di 3 Asus VivoTab RT TF600T Webcam Replacement, Webcam: passo 1, immagine 2 di 3 Asus VivoTab RT TF600T Webcam Replacement, Webcam: passo 1, immagine 3 di 3
    • Make sure the tablet is turned off.
    • Remove the tablet from the attached keyboard.
    • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
  2. Asus VivoTab RT TF600T Webcam Replacement: passo 2, immagine 1 di 3 Asus VivoTab RT TF600T Webcam Replacement: passo 2, immagine 2 di 3 Asus VivoTab RT TF600T Webcam Replacement: passo 2, immagine 3 di 3
    • Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
    • Use the Phillips screwdriver size #000 to remove the two 1.59 mm screws.
  3. Asus VivoTab RT TF600T Webcam Replacement: passo 3, immagine 1 di 2 Asus VivoTab RT TF600T Webcam Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to help detach the screen from the back panel.
    • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
    • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
  4. Asus VivoTab RT TF600T Webcam Replacement: passo 4, immagine 1 di 2 Asus VivoTab RT TF600T Webcam Replacement: passo 4, immagine 2 di 2
    • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
    • Lift the screen to view the inside of the tablet.
  5. Asus VivoTab RT TF600T Webcam Replacement: passo 5, immagine 1 di 2 Asus VivoTab RT TF600T Webcam Replacement: passo 5, immagine 2 di 2
    • Before disconnecting the display cables, refer to the image to turn off the switch labeled DIP; this switch is used to de-energize the system.
    • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
  6. Asus VivoTab RT TF600T Webcam Replacement: passo 6, immagine 1 di 3 Asus VivoTab RT TF600T Webcam Replacement: passo 6, immagine 2 di 3 Asus VivoTab RT TF600T Webcam Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Rotate the Tablet clockwise, so that the webcam is facing away from you.
    • Gently lift the webcam out of its socket with the precision tweezers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 231
