Introduzione
When removing the battery, it may get damaged. The battery is rechargeable however may need replacement if it is broken.
Strumenti
Parti
Nessuna parte specificata.
First take the pen out, it may get in the way when you are opening the device. If you have a memory card, you should also remove it.
Use the plastic opening tool to pry open the edges of the cover. The memory card slot is very useful for getting started.
Disconnect the battery from the motherboard by pulling the side of the black plastic up.
To reassemble your device, follow these instructions in reverse order. You will need adhesive to keep the battery stuck if the tape stops working.
