Salta al contenuto principale
Asus VivoBook X540SA-BPD0602V Speaker Replacement
Cosa ti serve
  1. Asus VivoBook X540SA-BPD0602V Speaker Replacement, Keyboard: passo 1, immagine 1 di 1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 4, immagine 1 di 1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 5, immagine 1 di 1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 6, immagine 1 di 1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Speaker Replacement, Battery: passo 7, immagine 1 di 1
    • Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not reuse them.
  8. Asus VivoBook X540SA-BPD0602V Speaker Replacement, Disk Drive: passo 8, immagine 1 di 1
    • The Disk Drive is located within the upper right hand corner of the laptop.
  9. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
    • Note which screws go where. The two smaller screws fasten onto the disc drive, while the three larger screws secure the drive on the outside.
  10. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 10, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
  11. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 11, immagine 1 di 1
    • After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
  12. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 12, immagine 1 di 1
    • Slide the disc drive to the right, removing it from the laptop case.
  13. Asus VivoBook X540SA-BPD0602V Speaker Replacement, Hard Drive: passo 13, immagine 1 di 1
    • The Hard Drive is located in the bottom right hand corner. It should be the device covered in black foam.
    • Do not remove the foam. It's anti-static foam and protects the hard drive from static and any bumps as you move around your device.
  14. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 14, immagine 1 di 1
    • Using the Phillips #0 screwdriver, unscrew the four (5.7cm) screws around the hard drive.
  15. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 15, immagine 1 di 1
    • Using the blue plastic opening tool in the iFixit tool kit, slide the hard drive to the right to remove it from the case.
    • Some models don't come with a foam insert. This will cause a bit of a rattle if you're replacing the old hard drive with an SSD drive.
  16. Asus VivoBook X540SA-BPD0602V Speaker Replacement, Speaker: passo 16, immagine 1 di 2 Asus VivoBook X540SA-BPD0602V Speaker Replacement, Speaker: passo 16, immagine 2 di 2
    • Disconnect speaker wire from motherboard.
  17. Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 17, immagine 1 di 3 Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 17, immagine 2 di 3 Asus VivoBook X540SA-BPD0602V Speaker Replacement: passo 17, immagine 3 di 3
    • Gently use the metal spudger to loosen speaker from adhesive, by first loosening the far right side and working your way to the left.
    • When removing the speaker, you may hear a cracking sound. This is okay; it is just the speaker separating from the adhesive.
Conclusione
Taylor Peters
Membro da: 11/01/18
309 Reputazione
2 Guide realizzate
IUPUI, Team S2-G6, Harley Fall 2018 Membro di IUPUI, Team S2-G6, Harley Fall 2018
IUPUI-HARLEY-F18S2G6
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,105
