Salta al contenuto principale
Asus VivoBook X540SA-BPD0602V Keyboard Replacement
Cosa ti serve
  1. Asus VivoBook X540SA-BPD0602V Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: passo 4, immagine 1 di 1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: passo 5, immagine 1 di 1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: passo 6, immagine 1 di 1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
Conclusione
Altre 5 persone hanno completato questa guida.
Ziyad Alharbi
Membro da: 10/18/17
136 Reputazione
1 Guida realizzata
USF Tampa, Team S1-G111, Cagle Fall 2017 Membro di USF Tampa, Team S1-G111, Cagle Fall 2017
USFT-CAGLE-F17S1G111
5 Membri
14 Guide realizzate
2Commenti sulla guida
My laptop name asus
The problem is keyboard do not working
Then to solve the keyboard problem please tell me that
Deepak - Replica
How to repair at home the keyboard
Please send me the video of repair the laptop
Deepak - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,901
