Salta al contenuto principale
Asus VivoBook X202E-DB21T Motherboard Replacement
Cosa ti serve
  1. Asus VivoBook X202E-DB21T Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 2, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 3, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Motherboard Replacement, Hard Drive: passo 6, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 7, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement: passo 7, immagine 2 di 2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
  8. Asus VivoBook X202E-DB21T Motherboard Replacement, CMOS Battery: passo 8, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement, CMOS Battery: passo 8, immagine 2 di 2
    • Unplug and remove the CMOS battery.
  9. Asus VivoBook X202E-DB21T Motherboard Replacement, Motherboard: passo 9, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement, Motherboard: passo 9, immagine 2 di 2
    • Unscrew the five 5mm screws holding the left board together.
  10. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 10, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement: passo 10, immagine 2 di 2
    • Unplug the two connectors on the left board.
  11. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 11, immagine 1 di 3 Asus VivoBook X202E-DB21T Motherboard Replacement: passo 11, immagine 2 di 3 Asus VivoBook X202E-DB21T Motherboard Replacement: passo 11, immagine 3 di 3
    • Remove the single 3mm screw from the sound chip.
    • Unplug the sound chip.
    • Remove the sound chip.
  12. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the six 4mm screws holding the fan and CPU cover.
  13. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 13, immagine 1 di 2 Asus VivoBook X202E-DB21T Motherboard Replacement: passo 13, immagine 2 di 2
    • Unplug the fan.
    • Remove the fan and CPU cover.
  14. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 14, immagine 1 di 1
    • Unscrew the nine 4mm screws holding the right board together.
  15. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 15, immagine 1 di 1
    • Remove the two remaining connectors on the board.
  16. Asus VivoBook X202E-DB21T Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove the right board.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,573
