Salta al contenuto principale
Asus VivoBook X202E-DB21T CMOS Battery Replacement
Cosa ti serve
  1. Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 2, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 2, immagine 2 di 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 3, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 3, immagine 2 di 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: passo 6, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: passo 6, immagine 2 di 2
    • Unplug and remove the CMOS battery.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 112
Tutti i Tempi: 7,433
