Salta al contenuto principale
Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement
Cosa ti serve
  1. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement, Wifi Chip: passo 1, immagine 1 di 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: passo 2, immagine 1 di 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: passo 3, immagine 1 di 1
    • Use a Phillips J0 screwdriver to remove the one black 3mm screw.
  4. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: passo 4, immagine 1 di 1
    • Use an up and away motion to pull the module out of its slot.
  5. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use precision tweezers to pry the black wire with a gold plug off the main gold plug on the module.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 728
