Salta al contenuto principale
Asus VivoBook S200E-RHI3T73 Screen Replacement
Cosa ti serve
  1. Asus VivoBook S200E-RHI3T73 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 2, immagine 1 di 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 3, immagine 1 di 1
    • Use a metal spudger to remove the clear screen protector from its backing.
    • Apply ample force along the bottom of the screen protector.
  4. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the four 2mm silver screws located at each of the four corners of the screen.
  5. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Gently lift the screen up and over.
    • Use tweezers to remove the EX2 LVDS connector cable that connects the screen and the laptop.
    • Remove the screen.
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,154
