Salta al contenuto principale
Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement
Cosa ti serve
  1. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Battery: passo 1, immagine 1 di 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  2. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 2, immagine 1 di 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 2, immagine 2 di 2
    • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
  3. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using a set of precision tweezers, lift the motherboard connector tab.
  4. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 4, immagine 1 di 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 4, immagine 2 di 2
    • Use a nylon spudger or your fingers to gently pry the battery up.
    • Remove the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): passo 5, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm panel screws.
    • Gently remove back panel
    • Be aware of sharp metal edges once the panel is removed.
  6. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 6, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  7. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 7, immagine 1 di 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 7, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the five 5mm screws on the fan.
    • Peel the protective wire tape off of the multicolored wires.
  8. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 8, immagine 1 di 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 8, immagine 2 di 2
    • Use the precision tweezers to disconnect the wires and gently remove the fan.
    • Be gentle so as not to break wires.
  9. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 9, immagine 1 di 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: passo 9, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the eight 6mm PCB board screws.
    • Remove the PCB board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 385
