Salta al contenuto principale
Asus VivoBook S200E-RHI3T73 Keyboard Replacement
Cosa ti serve
  1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm screws and lift the panel.
    • Be aware of sharp metal edges once the panel is removed.
  2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 2, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the twelve 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  3. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 3, immagine 1 di 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 3, immagine 2 di 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the Phillips #0 screwdriver to remove the five 5mm screws around the fan.
    • Use the precision tweezers to unplug the fan cords.
    • Be cautious of pulling the cords.
  4. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 4, immagine 1 di 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 4, immagine 2 di 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use the Phillips#0 screwdriver to unscrew the 3.5mm screws from around the motherboard and the 6mm screws from around the PCB.
    • Double check for unloosened screws. Bending the boards can damage the hardware.
  5. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 5, immagine 1 di 2 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 5, immagine 2 di 2
    • Use the Phillips#0 screwdriver to remove the 50mm screws on the boarder of the metal panel.
    • Be cautious of sharp metal edges.
    • Carefully remove the panel. Without care it will bend and be difficult to reassemble.
  6. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 6, immagine 1 di 1
    • Using the Phillips#0 screwdriver, remove the 50mm screws surrounding the keyboard.
    • Gently remove the keyboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 613
