Salta al contenuto principale
Asus VivoBook Q302LA-BHI3T09 Fan Replacement
Cosa ti serve
  1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: passo 1, immagine 1 di 2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: passo 2, immagine 1 di 2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: passo 2, immagine 2 di 2
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: passo 3, immagine 1 di 3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: passo 3, immagine 2 di 3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: passo 3, immagine 3 di 3
    • Remove the following screws that mount the fan and heatsink to the motherboard:
    • Three 3.0 mm screws for the fan
    • Four 2.0 mm screws for the heatsink
    • The bottom of the heatsink will contain thermal paste. Avoid making contact with this as any dirt or oils can reduce the effectiveness of the cooler.
Conclusione
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 189
