Salta al contenuto principale
Asus VivoBook Q200E-BSI3T08 Display Replacement
Cosa ti serve
  1. Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: passo 1, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: passo 1, immagine 2 di 2
    • First open the laptop and place it so that you have access to the side of the display.
    • Next you want to place the laptop in a position where you have easy access to the display.
    • Use a metal or a plastic prying tool to split the front and back of the display.
    • Start on the side and work your way around.
  2. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 2, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 2, immagine 2 di 2
    • Pull the clear plastic display down from the bottom right and left.
    • If pulled from the top you might crack the actual plastic.
  3. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 3, immagine 1 di 1
    • Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
  4. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 4, immagine 1 di 1
    • Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 5, immagine 1 di 1
    • Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
  6. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 6, immagine 1 di 1
    • Here is a picture of the connection that needs to be removed to free the display.
    • Pull connection from the plastic on the sides not the wires as these are fragile.
  7. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 7, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 7, immagine 2 di 2
    • Once this connection is removed here's what that should look.
  8. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 8, immagine 1 di 1
    • Remove display and place your new one in it's place.
Conclusione
IUPUI, Team S4-G4, Wilson Summer 2017 Membro di IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Membri
7 Guide realizzate
1Commento della guida
You are suppose to remove the hinge/screen assembly from the laptop chasis before starting step 1, if you don't you will break the digitizer author please fix the guide
Nicholas Chan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,894
