Introduzione
This guide will show you how to locate and replace the display if experiencing display issues.
Cosa ti serve
First open the laptop and place it so that you have access to the side of the display.
Next you want to place the laptop in a position where you have easy access to the display.
Use a metal or a plastic prying tool to split the front and back of the display.
Start on the side and work your way around.
Un commento
You are suppose to remove the hinge/screen assembly from the laptop chasis before starting step 1, if you don't you will break the digitizer author please fix the guide
