Salta al contenuto principale
Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement
Cosa ti serve
  1. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: passo 3, immagine 1 di 2 Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement, Cooling Fan: passo 4, immagine 1 di 1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Unplug the power bus for the fan.
  6. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Lift up and remove the cooling fan from the slot.
Conclusione
IUPUI, Team S4-G4, Wilson Summer 2017 Membro di IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 506
