Salta al contenuto principale
Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement
Cosa ti serve
  1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Battery: passo 1, immagine 1 di 2 Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Battery: passo 1, immagine 2 di 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 3, immagine 1 di 2 Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 3, immagine 2 di 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 4, immagine 1 di 2 Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 4, immagine 2 di 2
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 5, immagine 1 di 1
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Fan: passo 6, immagine 1 di 1
    • Gently peel off the tape from the fan.
  7. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 7, immagine 1 di 2 Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 7, immagine 2 di 2
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 8, immagine 1 di 1
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 9, immagine 1 di 2 Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: passo 9, immagine 2 di 2
    • Grab the sides of the fan assembly and remove it by lifting upwards.
  10. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Thermal Paste: passo 10, immagine 1 di 2 Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Thermal Paste: passo 10, immagine 2 di 2
    • Use isopropyl alcohol and a cotton ball to clean thermal paste off the CPU and back of the heatsink.
    • Apply a drop of thermal paste on the CPU.
    • Carefully place heatsink/fan assembly back.
Conclusione
Bryann Tan
Membro da: 09/25/16
877 Reputazione
6 Guide realizzate
USF Tampa, Team 16-2, Eyestone Fall 2016 Membro di USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,009
