Salta al contenuto principale
Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement
Cosa ti serve
  1. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement, Hard Disk Drive: passo 1, immagine 1 di 1
    • Disconnect laptop from the power supply.
  2. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
  3. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 3, immagine 1 di 2 Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 3, immagine 2 di 2
    • Use a metal or nylon spudger to pry open the back cover on all sides.
    • Remove the back cover to access the inside where the hard disk drive is located.
  4. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 4, immagine 1 di 1
    • Locate the hard-drive.
    • Disconnect the hard disk drive from its connectors, and remove the drive.
    • Place the new HDD in the same location and orientation.
Conclusione
Un commento
Hey, do you by any chance have the reference for the battery in the Asus TP410U ? Thank you!
Matt JBOM - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,663
