Salta al contenuto principale
Asus VivoBook E203MA-TBCL432B Power Button Replacement
Cosa ti serve
  1. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Back Panel: passo 1, immagine 1 di 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 2, immagine 1 di 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 2, immagine 2 di 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 3, immagine 1 di 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 3, immagine 2 di 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 3, immagine 3 di 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: passo 4, immagine 1 di 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: passo 4, immagine 2 di 2
    • Remove the single connector by first pulling back the white tab and then pulling the connector out with the blue tab.
  5. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 5, immagine 1 di 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 5, immagine 2 di 2
    • Remove the single 2 mm screw with a Phillips #0 screwdriver.
  6. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 6, immagine 1 di 1
    • Now that the power button component is free, lift it up and out of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,006
