Salta al contenuto principale
Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement
Cosa ti serve
  1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Back Panel: passo 1, immagine 1 di 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 2, immagine 1 di 3 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 2, immagine 2 di 3 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 3, immagine 1 di 3 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 3, immagine 2 di 3 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 3, immagine 3 di 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Headphone Jack and USB Port: passo 4, immagine 1 di 2 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Headphone Jack and USB Port: passo 4, immagine 2 di 2
    • Disconnect the ribbon cable located above the battery.
    • Flip up the locking tab on the Zero Insertion Force (ZIF) connector, then slide the cable away.
  5. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 5, immagine 1 di 2 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 5, immagine 2 di 2
    • Disconnect the small white ribbon cable that is connected to the unit that holds the USB and headphone jack.
    • First, lift the white tab that locks onto the blue tab and then pull the cable out by the blue tab.
  6. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 6, immagine 1 di 2 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 6, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the two 2 mm screws on the top left and bottom left of the component with the headphone jack and USB port.
  7. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 7, immagine 1 di 2 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: passo 7, immagine 2 di 2
    • Remove the headphone jack and USB printed circuit board by lifting it directly up and out of the laptop.
Conclusione
Melanie
Membro da: 03/21/19
280 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 666
