Salta al contenuto principale
Asus VivoBook E203MA-TBCL432B Back Panel Replacement
Cosa ti serve
  1. Asus VivoBook E203MA-TBCL432B Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Back Panel Replacement: passo 2, immagine 1 di 3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: passo 2, immagine 2 di 3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Back Panel Replacement: passo 3, immagine 1 di 3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: passo 3, immagine 2 di 3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: passo 3, immagine 3 di 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
Conclusione
To reassemble your device, follow these instructions in reverse order. The plastic opening tool is not required to reattach the panel. Place the panel in its proper position, then push it firmly down. Do this on all sides of the panel until you hear a click.
Altre 2 persone hanno completato questa guida.
Brad
Membro da: 03/20/19
539 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 791
