Salta al contenuto principale
Asus V6800V Wireless Card Replacement
Cosa ti serve
  1. Asus V6800V Wireless Card Replacement, Battery: passo 1, immagine 1 di 2 Asus V6800V Wireless Card Replacement, Battery: passo 1, immagine 2 di 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Wireless Card Replacement, Wireless Card: passo 2, immagine 1 di 2 Asus V6800V Wireless Card Replacement, Wireless Card: passo 2, immagine 2 di 2
    • Remove the six screws highlighted on the picture.
    • Once the screws are removed, pry open the panel with the pry tool.
    • It should now look like this.
  3. Asus V6800V Wireless Card Replacement: passo 3, immagine 1 di 2 Asus V6800V Wireless Card Replacement: passo 3, immagine 2 di 2
    • After removing that panel, locate the screw on the right as highlighted.
    • Remove that screw.
    • Pry open the side panel with the small prying tool as shown.
    • That panel should pop off and the wireless card will now be easily visible.
  4. Asus V6800V Wireless Card Replacement: passo 4, immagine 1 di 1
    • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
    • Repeat for the other one.
    • Place the gold connectors aside.
  5. Asus V6800V Wireless Card Replacement: passo 5, immagine 1 di 3 Asus V6800V Wireless Card Replacement: passo 5, immagine 2 di 3 Asus V6800V Wireless Card Replacement: passo 5, immagine 3 di 3
    • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
    • Place one finger on each tab and press each to the side away from the wireless card as shown.
    • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
  6. Asus V6800V Wireless Card Replacement: passo 6, immagine 1 di 2 Asus V6800V Wireless Card Replacement: passo 6, immagine 2 di 2
    • To remove the wireless card, pull the card directly out.
    • It should come out with just a little bit of pressure.
    • It should look as shown when removed.
Conclusione
Steven
Membro da: 06/24/10
32 Reputazione
2 Guide realizzate
Cal Poly, Team 2-9, Johann Summer 2010 Membro di Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,839
