Introduzione
Removing the keyboard is a useful way to clean it, or it can be replaced if broken.
The keyboard needs to be removed if you wish to remove the top part of the case for further maintenance of the computer.
Parti
Nessuna parte richiesta.
First, the screws on the bottom need to be removed first.
  • First, the screws on the bottom need to be removed first.
Aggiungi Commento
There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
  • There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
Aggiungi Commento
  • Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
Aggiungi Commento
  • Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
Aggiungi Commento
  • Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
Aggiungi Commento
  • Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
Aggiungi Commento
  • To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401
  • You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Brian Tubb
Membro da: 24/06/2010
280 Reputazione
3 Guide realizzate
Cal Poly, Team 2-9, Johann Summer 2010 Membro di Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,185
