Salta al contenuto principale
Asus V6800V CD/DVD Drive Replacement
Cosa ti serve
  1. Asus V6800V CD/DVD Drive Replacement, Battery: passo 1, immagine 1 di 2 Asus V6800V CD/DVD Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: passo 2, immagine 1 di 2 Asus V6800V CD/DVD Drive Replacement, Hard Drive: passo 2, immagine 2 di 2
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: passo 3, immagine 1 di 2 Asus V6800V CD/DVD Drive Replacement: passo 3, immagine 2 di 2
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: passo 4, immagine 1 di 2 Asus V6800V CD/DVD Drive Replacement: passo 4, immagine 2 di 2
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: passo 5, immagine 1 di 2 Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: passo 5, immagine 2 di 2
    • Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
    • Insert a spudger into the hole to carefully push the CD/DVD drive out.
Conclusione
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
Jong Park
Membro da: 06/24/10
114 Reputazione
5 Guide realizzate
Cal Poly, Team 2-9, Johann Summer 2010 Membro di Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 4,289
