Salta al contenuto principale
Asus V500CA-DB51T WiFi Card Replacement
Cosa ti serve
  1. Asus V500CA-DB51T WiFi Card Replacement, Battery: passo 1, immagine 1 di 2 Asus V500CA-DB51T WiFi Card Replacement, Battery: passo 1, immagine 2 di 2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T WiFi Card Replacement: passo 2, immagine 1 di 2 Asus V500CA-DB51T WiFi Card Replacement: passo 2, immagine 2 di 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T WiFi Card Replacement: passo 3, immagine 1 di 1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T WiFi Card Replacement: passo 4, immagine 1 di 2 Asus V500CA-DB51T WiFi Card Replacement: passo 4, immagine 2 di 2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T WiFi Card Replacement: passo 5, immagine 1 di 3 Asus V500CA-DB51T WiFi Card Replacement: passo 5, immagine 2 di 3 Asus V500CA-DB51T WiFi Card Replacement: passo 5, immagine 3 di 3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T WiFi Card Replacement, WiFi Card: passo 6, immagine 1 di 2 Asus V500CA-DB51T WiFi Card Replacement, WiFi Card: passo 6, immagine 2 di 2
    • Locate the section of the device that houses the WiFi Card.
    • This should be a white, square-shaped object located just above the left end of the battery.
  7. Asus V500CA-DB51T WiFi Card Replacement: passo 7, immagine 1 di 2 Asus V500CA-DB51T WiFi Card Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the black and white wires that are connected to the WiFi card by gently pulling them upward with a pair of tweezers.
    • Using the tweezers, gently pull the WiFi card out away from yourself.
    • If you try pulling up you could cause damage, so be sure to slowly and gently pull the card away from yourself.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 250
