Salta al contenuto principale
Introduzione
Replacing the RAM is very simple in this case. Removing a few screws and a plastic plate will reveal the RAM which can be replaced. This repair would be needed if the RAM is old and PC performance is lacking.
Ricambi
Nessuna parte specificata.
  1. Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  2. Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed. Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed. Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 60
