Salta al contenuto principale
Asus UL80VT Motherboard Replacement
Cosa ti serve
  1. Asus UL80VT Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: passo 2, immagine 1 di 2 Asus UL80VT Motherboard Replacement: passo 2, immagine 2 di 2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: passo 3, immagine 1 di 1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: passo 4, immagine 1 di 3 Asus UL80VT Motherboard Replacement, Hard Drive: passo 4, immagine 2 di 3 Asus UL80VT Motherboard Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: passo 5, immagine 1 di 2 Asus UL80VT Motherboard Replacement: passo 5, immagine 2 di 2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: passo 6, immagine 1 di 1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: passo 7, immagine 1 di 3 Asus UL80VT Motherboard Replacement: passo 7, immagine 2 di 3 Asus UL80VT Motherboard Replacement: passo 7, immagine 3 di 3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: passo 8, immagine 1 di 2 Asus UL80VT Motherboard Replacement, Keyboard: passo 8, immagine 2 di 2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: passo 9, immagine 1 di 1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: passo 10, immagine 1 di 1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: passo 11, immagine 1 di 1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: passo 12, immagine 1 di 2 Asus UL80VT Motherboard Replacement: passo 12, immagine 2 di 2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: passo 13, immagine 1 di 1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: passo 15, immagine 1 di 1
    • Lift the motherboard out of the laptop and remove it from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 434
