Salta al contenuto principale
Introduzione
The keyboard is the appliance used to input your laptop with data, text, and commands. If input is unresponsive. The keyboard will need to be replaced. This guide will walk you through the process.
Ricambi
Nessuna parte specificata.
  1. Open laptop so the keyboard is accessible. Insert a plastic prying tool and push and then pull to release the keyboard from the device.
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  2. Lift keyboard and remove ZIF connector cables.
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 69
