Salta al contenuto principale
Asus UL80VT Battery Replacement
  1. Asus UL80VT Battery  Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Battery  Replacement: passo 2, immagine 1 di 2 Asus UL80VT Battery  Replacement: passo 2, immagine 2 di 2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Battery  Replacement: passo 3, immagine 1 di 1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 193
