Salta al contenuto principale
Asus UL30VT-X1 Battery Replacement
Cosa ti serve
  1. Asus UL30VT-X1 Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus UL30VT-X1 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over onto the back. (Second Image)
  2. Asus UL30VT-X1 Battery Replacement: passo 2, immagine 1 di 2 Asus UL30VT-X1 Battery Replacement: passo 2, immagine 2 di 2
    • Locate the two battery locks. (First Image)
    • The battery lock on the left will need to be unlocked first which is done by pushing the lock to the left. (Second Image)
    • A red line should show which indicates it is unlocked.
  3. Asus UL30VT-X1 Battery Replacement: passo 3, immagine 1 di 1
    • Unlock the right lock by moving it to the right while simultaneously pushing upwards on the battery.
    • The battery should slide out of place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 268
