Salta al contenuto principale
Asus U56E-BBL6 Motherboard Replacement
Cosa ti serve
  1. Asus U56E-BBL6 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Motherboard Replacement: passo 2, immagine 1 di 1
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Motherboard Replacement, Back Panel: passo 3, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement, Back Panel: passo 3, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Motherboard Replacement, RAM: passo 5, immagine 1 di 1
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Motherboard Replacement: passo 6, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 6, immagine 2 di 2
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Motherboard Replacement: passo 7, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 7, immagine 2 di 2
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Motherboard Replacement, Keyboard: passo 8, immagine 1 di 1
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Motherboard Replacement: passo 9, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 9, immagine 2 di 2
  10. Asus U56E-BBL6 Motherboard Replacement: passo 10, immagine 1 di 1
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Motherboard Replacement: passo 11, immagine 1 di 1
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Motherboard Replacement: passo 12, immagine 1 di 1
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Motherboard Replacement: passo 13, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 13, immagine 2 di 2
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  14. Asus U56E-BBL6 Motherboard Replacement, Optical Drive: passo 14, immagine 1 di 1
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  15. Asus U56E-BBL6 Motherboard Replacement: passo 15, immagine 1 di 1
    • Remove the optical drive by sliding it out from the case.
  16. Asus U56E-BBL6 Motherboard Replacement, Motherboard: passo 16, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the three screws.
  17. Asus U56E-BBL6 Motherboard Replacement: passo 17, immagine 1 di 3 Asus U56E-BBL6 Motherboard Replacement: passo 17, immagine 2 di 3 Asus U56E-BBL6 Motherboard Replacement: passo 17, immagine 3 di 3
    • Lift up the ribbon cable connector on the bottom right corner.
    • Gently pry the cable away from the connection.
  18. Asus U56E-BBL6 Motherboard Replacement: passo 18, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 18, immagine 2 di 2
    • Remove the 4 pronged connection on the bottom right corner of the motherboard.
  19. Asus U56E-BBL6 Motherboard Replacement: passo 19, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 19, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the two screws.
    • Holding the board firmly with two fingers, pull outward, disconnecting it from the contacts.
  20. Asus U56E-BBL6 Motherboard Replacement: passo 20, immagine 1 di 1
    • Repeat the previous step and remove the two wired connection next to the card.
  21. Asus U56E-BBL6 Motherboard Replacement: passo 21, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 21, immagine 2 di 2
    • Remove the cable at the top left of the motherboard.
    • This cable is held in by a magnetic connection. Be sure to lift up and away when disconnecting.
  22. Asus U56E-BBL6 Motherboard Replacement: passo 22, immagine 1 di 2 Asus U56E-BBL6 Motherboard Replacement: passo 22, immagine 2 di 2
    • Using both hands, lift the motherboard up and out from the case
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 611
