Salta al contenuto principale
Asus U56E Laptop Screen Replacement
Cosa ti serve
  1. Asus U56E Laptop Screen Replacement, Screen: passo 1, immagine 1 di 2 Asus U56E Laptop Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Position the laptop on a flat, stable surface, with the underside facing upward.
  2. Asus U56E Laptop Screen Replacement: passo 2, immagine 1 di 3 Asus U56E Laptop Screen Replacement: passo 2, immagine 2 di 3 Asus U56E Laptop Screen Replacement: passo 2, immagine 3 di 3
    • Make sure the laptop is unplugged before removing the battery to avoid risk of electric shock.
    • Slide the two battery lock switches toward each other.
    • Lift the battery to remove it from the laptop.
  3. Asus U56E Laptop Screen Replacement: passo 3, immagine 1 di 3 Asus U56E Laptop Screen Replacement: passo 3, immagine 2 di 3 Asus U56E Laptop Screen Replacement: passo 3, immagine 3 di 3
    • Remove the 3 Phillips #00 screws holding on the back cover of the laptop.
    • Lift the cover, exposing the laptop hard drive and RAM.
  4. Asus U56E Laptop Screen Replacement: passo 4, immagine 1 di 2 Asus U56E Laptop Screen Replacement: passo 4, immagine 2 di 2
    • Remove the eight small screws holding the hard drive in.
    • The hard drive cover can now be removed by lifting the tab on the left.
  5. Asus U56E Laptop Screen Replacement: passo 5, immagine 1 di 1
    • Gently slide the hard drive left toward the edge of the laptop, then lift up to remove it.
  6. Asus U56E Laptop Screen Replacement: passo 6, immagine 1 di 2 Asus U56E Laptop Screen Replacement: passo 6, immagine 2 di 2
    • Remove the 4 Phillips #00 screws around the RAM.
  7. Asus U56E Laptop Screen Replacement: passo 7, immagine 1 di 2 Asus U56E Laptop Screen Replacement: passo 7, immagine 2 di 2
    • Remove the 10 Phillips #00 screws from the bottom of the laptop.
    • Remove 10 Phillips #000 screws from under the battery.
  8. Asus U56E Laptop Screen Replacement: passo 8, immagine 1 di 2 Asus U56E Laptop Screen Replacement: passo 8, immagine 2 di 2
    • Slide the optical drive out of the laptop.
    • Gently lift the rear plastic hinge cover to separate it from the laptop.
  9. Asus U56E Laptop Screen Replacement: passo 9, immagine 1 di 3 Asus U56E Laptop Screen Replacement: passo 9, immagine 2 di 3 Asus U56E Laptop Screen Replacement: passo 9, immagine 3 di 3
    • Remove the 3 Phillips #000 screws from each side of the hinge (six screws in total).
    • Gently lift the thin plastic cover from each side, exposing the laptop hinge.
    • Be aware of the thin cables still connected to the screen.
  10. Asus U56E Laptop Screen Replacement: passo 10, immagine 1 di 2 Asus U56E Laptop Screen Replacement: passo 10, immagine 2 di 2
    • Gently lift around the perimeter of keyboard to separate it from the laptop body.
    • It may help to use a Plastic Opening Tool.
    • Be careful not to pull too hard on the keyboard - It's connected to the motherboard with a thin ribbon cable!
  11. Asus U56E Laptop Screen Replacement: passo 11, immagine 1 di 3 Asus U56E Laptop Screen Replacement: passo 11, immagine 2 di 3 Asus U56E Laptop Screen Replacement: passo 11, immagine 3 di 3
    • Pull the display connector straight up to remove it from the motherboard.
    • Carefully detach the white and black WiFi antennas from the wireless adapter.
  12. Asus U56E Laptop Screen Replacement: passo 12, immagine 1 di 1
    • The screen can now be safely removed from the laptop.
Conclusione
David Zilar
Membro da: 09/29/15
167 Reputazione
1 Guida realizzata
Cal Poly, Team 14-5, Green Fall 2015 Membro di Cal Poly, Team 14-5, Green Fall 2015
CPSU-GREEN-F15S14G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,376
